R
Hi guys,
I seriously need help with this one.
I want to use the "AUTOTUNE" EFB in Unity pro along with the 'IMC' controller block.
How do you go about it? The Unity-Pro Process control User Guide says it is possible whereas in Unity-Pro help, it says that AUTOTUNE is only for the PIDFF & PI_B controllers.
Is there any way (or conversion formula) by which it is possible to pass the information obtained by the AUTOTUNE block 's 'PARA_C' output to the IMC controller's "PARA" input
Thank you for looking in,
Regards, & best wishes,
Raj S. Iyer
Raj S. Iyer
