T
I'm using KepServerEx V5 with Allen-Bradley ControlLogix Ethernet driver. I am trying to use the _System._Error and _System._NoError tags to indicate that the connection is OK.
If I disconnect the network cable at the PLC all the data point tag values show Quality = 'bad' but the _System variables don't change and, in particular, the _Error / _NoError bits don't change.
Any ideas?
Any ideas?
