L
I have been asked a question....which I don't know the answer to, hopefully someone here will have come across this before (I can't be the first).
I have a PLC that begins using Modbus Serial, then this gets converted/encapsulated into Modbus TCP/IP. I know this works in industry, so that part is fine.
What I want to know is, if I then encapsulate Modbus TCP/IP into HTTPS, should the end result still be achievable (i.e. reverse the process so the information can be read)?
Many thanks for any help.
Liam
Liam
