When paralleling 2 units together separate from the grid. i read that the voltages have to be the same so no circulating currents occur. So why is it that when i up/lower the voltage at a site the vars on that unit go up. is it taking more of the reactive load? or are there circulating currents. I was under the impression that when you up/lower the voltage nothing happens you just take more of the system vars.
like i know with the fuel fuel you raise fuel unit will take more watts.
does same thing happen with voltage and vars.
But where i'm getting mixed up is how can this jive with upping the voltage you would have 2 different voltages on the gensets and therefore have circulating currents.
