We have in our Frame 7 E gas turbine mist separator blower which is used for exhaust the vapor from lube oil reservoir via vent pipe line. We made extension of vent pipe line in order to exhaust the vapor outside the turbine building. Whereas the exhaust vapor before the extension was inside the turbine building. After this job was completed we faced problem in it which is leaking from flanges as well as accumulated vapor inside the reservoir. we checked the vent pipe line and we found no more vapor coming out. We consulted Hitachi and they replied the mist separator we have is old and stopped this product. Now we have to select new blower. The question is what are the criteria of selection blower with respect with vent pipe line?
