What will happen to a running gas turbine if the hydraulic oil pressure suddenly falls to zero? The GT is a GE make frame V machine. Hydraulic oil is used only for modulating the IGV and fuel bypass valve. I assume that it shall not trip the machine, but FSR/ fuel control will be out and IGV angle will be stuck at the last operating value. Please help.
