Assume I connect a -250 in to 250 in WC rosemount 3051SCD2A.. type transmitter such that the high side is connected with process line below atmospheric pressure (vacuum) while the low side is left open to atmosphere. the transmitter reads between 1 to 3 inch. Now if I reverse the connections, shouldn't the transmitter read the same. what is recommended connection for a below atmospheric pressure application. I have experienced unstable and wrong readings when the connections are reversed, but I am not sure what is causing it. Application is air and an analog gauge in parallel with transmitter is working absolutely fine.
