I
Hi People,
Hope you can help me. We have a bank of compressors running off a proprietary controller. The trouble is that on one of the compressors the on-board controller has no input to allow control of its load/unload state. This on-board controller relies only on the pressure transducer input (0 - 5vdc) to decide whether to open or close the load/unload solenoid. My idea is that I can build a little voltage regulator using an LM117 whose output is paralleled with the pressure transducers output and switched on from the bank controller to "trick" the on-board controller it has a high pressure state and will unload.
My question is; will this work, and is there any danger I will back feed the pressure transducer and damage it?
Any help would be mightily appreciated.
