Hi Guys,
We have 4 units of Frame 6B more than 20 years old. At this stage due to high demand we are aiming to use Peak Load mode instead of Base Load. I got pressure to find EOH or Maintenance Factor. I have read GE document it does not give me any good details apart from one equation. As per the equation it requires firing temperature. We do not have any arrangement in speedotronic for firing temperature and I need to calculate firing temperature. Is that any equation or formula which can give me firing temperature of frame 6b? I have gone through no. of threads but not getting clear details. Your response would be appreciated?
Note: I have all the details for PCD, Exhaust temperature, Gas (Fuel) flow. I have found one equation which is TF/TX = F(PCD+PA)/(PA+dPX)
Where TF=Firing temperature, Tx = Exhaust temperature, PA = Atmospheric pressure, dPX = Exhaust pressure drop. But do not know what is F?
