N
I have a system with Indramat CLM01.3M_ANW1, supply KDV2.3 and KDS1..-100-300-W1. The system worked OK but after 2 weeks started to "tremble" when is moving (not all the time). The motor is MAC112D-0-HD-4-C. I removed the analog set point signal from the converter and I generate my own 0-10V to be sure it is working. At low voltage is "trembling" but at high voltage is working fine. If I use the hole system in Test Mode the machine is working fine. I tested the motor without the encoders and is still tremble a little.
I could test the motor with other frequency converter (Siemens, Allen-Bradley..)??? It is having something special that must be used only with Indramat ??
