P
I want to ask about leveling standard bearings on GE MS9001E gas turbine. At the time of overhaul I found that the level of bearing 2 against to bearing 1 = 8 mm, and the level of the bearings 3 against to bearing 1 = 9 mm. Whether to frame 9, all the position bearing must be parallel or 1, 2, 3 bearings have a high distinction? Please advice
Reply to this post...
