I
We have PLC system with dual power supply 24V dc with OR gated diode to make 1oo2 for the loop voltages which connected to the digital input of the PLC. Surprising, thing is that when we try to measure the Power Supply voltage across the +ve and -ve points, I can read 24Vdc without any problem. But when the same measured points with respective to ground by the High end FLUKE multi-meter, I mean Red Lead at +ve of PS and Black lead to the ground, initially it shows 15Vdc and slowly it becomes 0Vdc. Why this is happening so?. I expect it should show +12Vdc with respective to GND with on measurement of +ve leg and -12vdc when we measure on -ve leg. Kindly reply asap.
