I Need to understand the various tripping points of gas turbine with respect to following points -
1. Trip point protects what?
2. what can be damaged if trip function failed to trip the machine?
trip points are
a. High exhaust pressure (63ET,63EA)
b. Low trip oil pressure (63HG-1,2,3)
c. Inlet air pressure high (63TF-1,2)
d. Low lube oil pressure (63QT-1,2)
which points are clear to me, i haven't asked.
One example for what i want here.
d. High lube oil temperature (26QT-1A,1B)
Ans :
1. (Trip point protects what?) It protects all bearing, LGB and AGB from high temperature.
2. (what can be damaged if trip function failed to trip the machine?) LGB and AGB and bearings will be damaged in absence of proper cooling.
Hope my question is clear.
trip points are
Ans :
