P
I have had a call out to a ship that is having problems with a reverse power alarm, causing a breaker to trip. The ship in question has just had its shaft generators overhauled away from the ship, and I have overhauled the breakers and Primary injected them, The breakers are Merlin Gerin Masterpact M breakers, they have a standard overurrent relay and are closed and tripped Via a PLC except in an overcurrent situation. when the shaft generators are run i am told they start fine but after a minute one trips on reverse power, the breaker does not trip only opens on command, now my question what would cause a reverse power fault? I have not been out to the ship yet so any ideas would be great, I don't usually deal with Generators just MCC'S and PLC systems so this is kinda new to me and college was a long time ago
