We have a siemens master drive for blower application. The drive was indicating 'DC link under voltage' fault. The service engineer checked the rectifier module and found it to be ok. He replaced the PCC (power control card). The problem got solved, but, after 30 days the same fault is coming again.
I checked the input AC supply to the drive and found it to be ok. Can somebody suggest me that how to check the rectifier module (made up of thyristor)?
