H
GeFS9001E unable to be back to service due to generator differential relay lockout and generator rotor field ground fault. This was the only process alarm on our operator interface display as at the time of the shutdown, that generator differential lockout.
Ge FS9001E gas turbine generator was shutdown normally due to inability of our gas supply company to deliver adequate gas pressure to us, but after sometimes there was gas restoration. however it was observed on the generator control panel in attempt to bring the unit generator differential lockout operation and at the ex2000 cubicle the generator field ground detector relay also operated but attempt made to clear these alarms were not successful. What one do when these the conditions prevailed. What positive response and suggestion shall be highly appreciated. Thanks.
