F
We are operating two GE Frame 5 gas turbines with dual fuel system. when turbine is shutdown with lube oil circulation on, worn AA compressor seals cause oil ingress into atomizing air circuit. Since we operate turbines only on gaseous fuel, we want to remove atomizing air compressor.
We have never performed any maintenance on accessory gearbox and atomizing air compressor before.
We need any procedure/instructions for atomizing air compressor removal on GE frame 5 MS5001P gas turbine.
