I have to connect ABB DCS with Emeson DCS. We choose Modbus RTU for this communication. But the problem is now two DCS hardware's modules are set as Master. It can not change. Is there any equipment between two Modbus RTU Master can help them for communication?
Otherwise, ABB module is only use Modbus RTU, but Emerson can use Modbus RTU or TCP. So, can I have solution to connect Modbus RTU with Modbus TCP with both side is master?
Thanks for your help!
