F
We have two frame 5 gas turbines (equipped with dual fuel nozzles but currently turbines operate on gaseous fuel) MS 5001P with Gardner Denver Atomizing Air compressor model SMAD/1. This is a screw compressor with timing gears so that screws do not come in contact during operation.
Previously there had been oil leakage from this compressor thru seal vents.
Recently during shutdown oil was observed from false start drain valve before startup of gas turbine. Upon further checking oil leakage was observed from atomizing air precooler drain and atomizing air manifold.
When gas turbine was started it tripped on overspeed and also fir was observed at gas turbine exhaust
Although these turbines are equipped with dual fuel system, these have been operating on gaseous fuel for a very long time. Also we do not have any paln to operate these turbines on liquid fuel.
We have no experience of any maintenance on atomizing air compressor.
to prevent oil leakage we have seal welded atomizing air and liquid fuel passages of fuel nozzle and atomizing air compressor discharge is currently being vented which causes a lot of noise
Can we operate compressor with suction and discharge blinded?
What will be the procedure for removal of compressor from accessory gear box?
Any supplier who can provide spares for this compressor? Gardner Denver says its obsolete
