Hello there!
As a project, I did the power flow for a certain system, and I got the results perfectly correct!
Now the thing is, we have one bus (bus 2) that exceeds the voltage limits +-5% of 1 p.u.
in the given data, we are given a capacitor (susceptance 0.3 p.u.) that we can use only on bus 2, in order to control the exceeding voltage.
What I used was, Q = |V|^2 * B (V here is voltage on bus 2, and B=0.3, the susceptance) and I came up with a value of Q, that when injected this amount in the system, the voltage on bus 2, and all the voltages are now inside the permissible limits!
But when referring back to the professor, he said that this is not the purpose of the control he wants! He wants us to know how much Q is needed to be injected in the system, so we can know how much of the 0.3 susceptance we are going to use!!
I couldn't find any other way to know that Q but trial and error! I mean if we can know the Q needed, what is the use of the power flow then??
can anyone help on this plz! Thank you
