Steam Turbine with High Vibration on Main Control Oil Pump
jignesh parmar
we have steam turbine 38.5 mw when main control oil pump running which is connected with gear box that time vibration found high in control oil line and vibration reaches up to 120 micron and vibration is cyclic. suddenly it is increase what is reason? control oil pressure 21kg/cm^2 and cyclic sound found in lub oil room near psv. during startup vibration are normal. but when we are taking load dat time it was happened and after FSNL we stopped auxiliary control oil pump which is motor drive
email:[email protected]
Dear Friend,
In starting you are using ALOP & after reaching to 95% off rated speed your MLOP will be in line, is it right?
If your system is like this, then tell me 1st is their any fluctuation in lub oil pressure at the time of starting? or at the time of Pump change over or in running condition?
