Hi
We have had problem with out gt's exhaust temperature spread since last summer HGPI. We replaced 2nd. and 3rd. buckets and 3rd. shrouds. Rest capital parts were refurbishment. During the test run GT tripped from high spread. We did analyze and change fuel nozzles positions. No help. We did more more inspections; air inlet condition, temperature sensors check, borescope inspection etc. No help. Then we replaced refurbishment fuel nozzles with totally new set. After that spread was not a problem anymore. This week we started GT again and same problem again. Now spread is ok between 0-25MW and after 38MW. Between that range it is living all the time, changes could be from 45 dec to 60 dec in 10 seconds!
Until now we have checked:
Exhaust temperature sensors and Mark IV chipsets OK
Bleed valve leakages, ok
Heat exchangers in air inlet, no leakages
Internal borescope inspection for the turbine, no findings
Does anyone has a good guess, what could be the problem?
Thanks for the tips!
