Earth fault protection of transmission line connected to step up transformer (delta 6.3kv and star 11kv). A ring core is provided on cable to delta side for earth fault protection through AE-102 RELAY. two ct on phase of this cable are used for over current protection through RMS 7990 RELAY. a separate ring core ct is installed on grounded neutral of star side which is used for sensing of earth fault for RMS 7990 Relay. Please advise that will this arrangement work as it is different from regular earth fault arrangement ???
