P
Our is a 50 KVA cummins make DG set using Power command 1302 controller. After starting the DG supply is extended to a local main breaker where neutral also earthed and then it is extended to a local distribution panel consists of number of MCB's. If we extend the supply to the local breaker it is normal. Once if supply extended to the load through any distribution panel through any MCB, irrespective capacity of load the DG is tripping. During each time it shows different fault code. coolant temp high, high AC voltage, low oil pressure etc. After disconnect the neutral it is not tripping. What could be the reason?
