hellow
I am working on G.E frame 6 mark 5 ms6001b gas turbine.
The gas turbine was running on fuel gas at full load 30 mw. All the reading parameters like exhaust was 500 deg c. ttxsp1, ttxsp2, ttxsp3 were 32 deg c approx, ambient temp 20 deg c. which were normal in such working conditions.
As we transferred the fuel from gas to distillate. After nearly four hours we found the gas manifold (common to all nozzles) was red hot. At the same time all the reading parameters like exhaust and spread where found normal approx same as explained above. The flow divider was showing distillate flow at 32 bars to all 10 nozzles.
what can be the reason for such red hot appearance of the gas manifold? due to hot gas return from combustion chamber?
please do mention if any further explanation required
regards
suhail
regards
suhail
