Frame 5 mark II GT we still unable to start the machine, the firing is ok , burners 7 & 8 are ok but when it reaches (2600 rpm) speed it trips on loss of flame.
33CS limit switch found faulty and replaced by new one and the power supply 125volt to the clutch found loose, repaired
First 2 starts on diesel fuel, reached 2500 rpm then tripped without any indication
one start on gas, it reached 3000 rpm then tripped without any indication.
14HA was OK but 14HS not OK.
What you recommend, what could be the reason?
Thanks alot
<b>moderator's note:</b> this looks like a continuation of an earlier thread, but I could not find it.
Thanks alot
