R
I an mew to this and need help.
While going through data sheets of flow meters (Venturi Meter, Orifice, Wedge flow meter) issued to different vendors, I observed the following..
A)Design pressure @Min & Max flow is given for Venturi whereas only max values in case of the Orifice and Wedge Meter.
B)Flow rate and Inlet Temp/Pressure @(Min/Normal/Max flow) is mentioned for Venturi and Wedge flow meter whereas for Orifice, Flow rate and Inlet Temp/Pressure @ (Normal/Max flow only) is mentioned.
C)Viscosity @ Normal flow is mentioned in Venturi & Orifice whereas for Wedge meter, Viscosity@ (Min/Normal/Max flow) is mentioned.
D)Vapor Pressure is not mentioned in Venturi & Orifice whereas for Wedge meter, Vapor pressure @ Min/Normal/Max flow is mentioned.
E)Critical pressure is mentioned for Venturi and Wedge flow whereas it is not mentioned for Orifice...
Please clarify the importance of these data
