hello
i am going to control the level of spherical tank using simulation tools such as labview, matlab.
can you pls tell if i should use any transfer function for the control valve? is it necessary or the controller output is enough which can be given directly to the process?
also can you suggest some ways to learn fuzzy logic rule base ?
thanks
thanks
