I am looking to carry out some preliminary data logging of variables stored in a WiHart/Modbus gateway. I am using ModScan by Win-Tech.
http://www.win-tech.com/html/modscan32.htm
I can start logging with ModScan fine, and do just have the trial version at the moment. However I have noticed a flaw. I cannot access the data file while ModScan is logging to it (because the file is in use), and when I come to restart the logging after importing the data into excel, ModScan insists on creating a new file (or overwriting the current one).
Quite an easy user work around, but runs the risk of deleting data rather easily or ending up with loads of individual data files and means that you will always have a moment with no data logging unless you set up a second log to cover the logging down time.
Is it possible to:
Access the data (by another program e.g.Excel) whilst logging?
Restart logging in the same file as previous?
Access the data file at all whilst in use?
Thanks in advance,
Adam
Is it possible to:
Thanks in advance,
Adam
