Hi experts;
I hope there are lot of peoples who use the HMI. Is any friend here who work on PeakHMI software? I have one issue regarding PeakHMI and its ODBC feature.
When ODBC in/out configured it writes the tags value to the excel fine, and read the static values also. But when excel sheet have a mathematical calculation on the write tags value and try to read that result in monitoring mode the ODBC IN is not read the updated values while excel update the results.
If open the excel sheet then write is not working, but read is fine.
If any friend use this feature of peakHMI please guide me how can i read and write the values from excel (excel sheet must have a formula calculation on write tag).
