If a load on an item is rated MAX AMP or FUSE SIZE 40 AMPS, is an amp draw figured on per wire of the 230 vac 1ph load? Or, is the total damp draw 20 per leg which would be 2 x 20= 40 Total amps. Would each leg read 20 AMPS on a 230 VAC 1 PH?
Thank you,
Jay Johnston
[email protected]
Thank you,
Jay Johnston
[email protected]
