Y
Y.K.JARIWALA
Dear Swapnil: Just to inform you that, installation used and mentioned in this thread works very well & temperature at pressure transmitter end is less than the permissible limits of transmitters. Even the temp is 1500 DEG C, should not matter much with this limits, unless Catch pot can not withstand this high temp. use the same MOC of your reactor.
Dear Richard: Just to know one point for NAK filled transmitters. what is solidification point for this fill? what additional arrangement is required to avoid solidification of this fill fluid?
I would really appreciate your feedback , we tried to locate this datasheets of transmitter[taylor Instruments], but this was long ago.
Jari
iconcnl [at] vsnl.net
Jari
