1. We need to have a measurement as well as control from DCS by replacing the existing MOBREY ultrasonic flow meters with a cost effective solution.
2. Based on an inquiry Emerson offered encapsulated Annubar with isolation valve solutions, but we're not sure of the accuracy of measurement and subsequent control from a DCS.
SIMILARLY WE ALSO HAVE RECEIVED QUOTE FROM another mfr with Mag. flow meter but the cost is very high.
Kindly advise what will be the best optimum solution while considering the reliability of measurement control as well as the cost effectiveness.
Pl. find existing application data sheet for reference.
Applications: Seawater
Line size: 36"/Q15A
Connection: 36"FLGD 150*RF (GROOVED)
PIPE MATERIAL: EPOXY LINED CS A106 GR B
Pressure: 1.5Barg Max
Normal: 0.9barg
Min: 0.9barg
Design: 5.0barg
Temp: 33degc max
Min: 22degc
Design: 85degc
Density: 1024 kg/cm3max
Min: 1027kg/cm3
Viscosity: 0.87
min: 1.08
MAX Flow rate: 4600m3/Hr
Normal Operating flow: 3200
Min flow rate: 320m3/Hr
Power SOURCE: 220Vac
o/p signal 4-20mAdc
Flange material: Integral to body
Measuring Scale: 0-5000m3/Hr
Protection: IP65
Line size: 36"/Q15A
Normal: 0.9barg
Min: 0.9barg
Design: 5.0barg
Temp: 33degc max
Min: 22degc
Design: 85degc
Min: 1027kg/cm3
Viscosity: 0.87
min: 1.08
o/p signal 4-20mAdc
Protection: IP65
