We have a problem with our gas turbine frame 6 GE cannot start because of alarm 'Starting Device Trip'. But our diesel starter rpm is about 2200 and enough to start turbine. We've checked all the relieve valve and replace with new one but also the same. However, we noticed that the torque converter pressure became "0 bar" after certain time. What is the solution for this type of problem?
Thank you
Thank you
