from the Ground fault department...
Equalizing Ground Fault
Posted by Shaheed on 2 July, 2012 - 6:46 am
How can we equalize the ground fault in ground fault current with open delta voltage?
A generator is protected by a ground fault CT of 200/5 set to 2.5A secondary. When synchronized with grid the NGR switched off and the only protection of ground fault depends on open delta PT 11KV/110V. Somebody can guide how much secondary voltage of open delta would be equal to 2.5A secondary fault current of CT?
Shaheed
Posted by Phil Corso on 2 July, 2012 - 11:44 am
Shaheed... PTs having their secondaries open-delta (connected) usually have their primary-windings connected phase-to-phase.
Thus, they will not respond to earth-faults!
Regards, Phil Corso
Posted by Phle Corso on 2 July, 2012 - 8:10 pm
Shaheed... also see:
http://www.control.com/thread/1026237476
Regards, Phil Corso
U: There's a U -- a Unicorn!
Run right up and rub its horn.
Look at all those points you're losing!
UMBER HULKS are so confusing.
-- The Roguelet's ABC
Advertise here
Advertisement
our advertisers
