from the High level control software department...
High level control platforms (WinPC server based) that can do PID and MPC?![]() ![]() |
Hi all,
Originally from the refining industry, I now found myself making cement clinker. Although there are quite a few products that specialize in cement and kiln control (typically rule-based/Fuzzy control), I am from a MPC background and believe there are optimization benefits to be had by applying MPC in the right way.
We have developed a ARC scheme with SISO PID's that work well. It runs on a WinPC based control server platform that interfaces the process with OPC. That architecture is fine because it rolls out quickly. To enhance what we already have, I am now on the look out for a "best of breed" software control platform that offers:
1) Basic and advanced PID function blocks
2) A decent linear function block library, without going into AI-type stuff
3) Drag and drop engineering for the above
4) MPC capability, as I understood it from my Profit Controller and DMC days. In other words, I don't want to engineer and "connect" 30 disparate low level objects that together make up a MPC controller, I want everything encapsulated in a common wrapper. I want to see frequency response unit step models, and the old MV/CV/DV engineering parameter configuration windows.
5) It must run reliably at 10 seconds execution intervals - I say this because some vendors' MPC engines don't guarantee performance below 30 seconds (no need to run that fast, blah blah...)
Can anybody on the forum recommend a product that combines the features above?
Kind regards.
Kind regards.
The trouble with doing something right the first time is that nobody
appreciates how difficult it was.
on 20 July, 2012 - 5:24 am
