from the Audio trigger department...
Simple, low cost audio file trigger / player
Application Questions and Problems topic
Posted by BluePhoton on 13 September, 2012 - 2:03 pm
What would be the easiest - simplest, and lowest cost approach to trigger and play an audio file from a switched input? This needs to be totally embedded and self running. Power on - and it should be ready to play.
When a (motion sensor) switch is triggered, I need an audio file to be played - (output to a powered speaker system).
Needs to be robust - should run 24/7 for years.
One approach is obviously to play a stored wav file from a small embedded SBC (like a PC104 or Raspberry-Pi) running a Linux embedded OS. Then connect the audio out to the amp/speakers. I find this however to be cumbersome and relatively expensive. I'm also not a SW programmer - so it would take me some time to make it work.
Some amps have a USB input- where I could connect a cheap MP3 player, but how can I trigger it to play?
Any other ideas / suggestions / recommendations?
Cost target < $40 (excluding amp & speakers)
I could dance till the cows come home. On second thought, I'd rather
dance with the cows till you come home.
-- Groucho Marx
Advertise here
Advertisement
our advertisers
