I have to integrate an pc application with a S7-1200 PLC. I would like to have the S7-1200 as Modbus TCP slave, and at the same time with a CM1241 the plc will read/write some registers from a Modbus Rtu network. As far as i now the S7-1200 can handle both communications without problems, can't it?
Anybody has done something similar successfully?
At www.modbus.pl you can download Siemens S7-1200 project with Modbus RTU Slave/Master and Modbus TCP/IP Server/Client.
Andrzej
Andrzej
In a five year period we can get one superb programming language. Only
we can't control when the five year period will begin.
