Hi..
Dear Experts
Which affect the site output of a typical MS9001 gas turbine;
.. Compressor inlet temp.
.. hear rate
.. air flow
How the curves and formulas are for the base load operation mode of gas turbine?
Thanks you.
Dear Experts
.. hear rate
.. air flow
Thanks you.
The main factors are
- ambient or air inlet temperature
- Altitude of the site above sea level
- condition of the compressor (cleanliness etc)
The curves you have assume a clean compressor.
What other queries relating to this do you have?
yes ambient temperature will play vital role along with other parameters like
1. compressor washing
2. fuel (gas / liquid) flow
3. exhaust temperature
4. hummudity
5. Atom. pressure
many formulas used for calculation, correction factor will be taken based on the performace curve provided by the manufacturer.
Take care
G.Rajesh
4. hummudity
5. Atom. pressure
Take care
G.Rajesh
For every credibility gap, there is a gullibility fill.
-- R. Clopton
on 1 October, 2012 - 2:03 pm
on 7 October, 2012 - 5:23 am
