I have searched Knowledge builder to no avail.
The new authorisation number has been obtained. This will be copied in to the Experion PKS Server Configuration Panel 'Change Licence' section. Updating the licence requires stopping the Experion Server. We have a redundant server system.
My question is; once the server is stopped then restarted, will the new licence be copied to server 'b' on sync? or do I need to install the new licence on server 'a' and 'b' separately?
I assume this change licence process should not cause any control interruptions if both servers are in sync when beginning?
Many thanks
Many thanks
You need to install the license in both servers
All bridge hands are equally likely, but some are more equally likely
than others.
-- Alan Truscott
on 2 October, 2012 - 8:35 pm
