from the Open Source Developer department...
water tank -- level control -- PID
Sensor technologies. topic
Posted by Allan on 5 October, 2012 - 9:25 am
I am looking forward to implement PID for water tank level control using Microcontroller.
I am facing difficulty to select sensors & components related to it.
To measure tank level i can use ultrasonic, hydrostatic pressure, capacitive and float sensor.
I can collect data for tank level into microcontroller from above mentioned sensors.
But i do not have much idea about following sensors :---
1> Sensor to measure water feed out of the tank ?
2> Which feed Valve to use to feed water into the tank ?
Suggest something which i can control using microcontroller ?
3> Also can solenoid valve can be used to control water feed into the tank.
Please try to suggest some less expensive sensor for which i can write control software in microcontroller to make an efficient system.
Please suggest on above points.
kind regards,
allan
Posted by Roy Matson on 5 October, 2012 - 6:11 pm
Hydrostatic pressure is very reliable
An orifice plate with DP cell, a Magnetic flowmeter ot Vortex shedding fowmeter
> Which feed Valve to use to feed water into the tank ? A globe or ball valve withelectric actuator
> Also can solenoid valve can be used to control vater feed into the tank.
Not the best choice if you are using PID, solenoids are more for On/Off control
Posted by Allan on 7 October, 2012 - 3:24 am
I was traveling so not able to reply, thanks for your reply Roy.
Can you suggest some part number from some vendor related to feed valve.
Can you suggest some part number from some vendor related to it.
Please suggest on this.
Posted by Bruno on 8 October, 2012 - 7:27 am
Hi Allan
> 1. Sensor to measure water feed out of the tank?
example: Compact orifice flowmeter like Emerson (3051SF), Siemens (SITRANS)
> 3. Also can solenoid valve can be used to control water feed into the tank.
Can you give us the volume of the tank and the value of inlet/outlet flow?
May be an on/off control mode is enough according to these values. the PID control is not always adapted to some process with large delay (dead time).
regards
Bruno
Arithmetic is being able to count up to twenty without taking off your
shoes.
-- Mickey Mouse
Advertise here
Advertisement
our advertisers
