from the Forum department...
communication between winCC and S7400
Human-Machine Interface and SCADA. topic
Posted by majid sheibaei on 15 October, 2012 - 2:05 am
How can I configure WinCC to have communication with S7400 via industrial ethernet? I have CP443 for ethernet communication that connected to HUB switch in redundant system. I want to configure WinCC to communicate with this system via ethernet without especial slot on PC.
Posted by Nguyen Hoang on 16 October, 2012 - 4:12 am
First, you must config CP443 in Hardware conf. and set a IP address for this module.
Download and check to sure that this module works properly.
Second, on the WinCC Explorer, please go into Tag Management, select Industry Ethernet and config IP address for communication with PLC S7-400.
After that, create tag as the same way as you do with MPI communication.
Good luck!
Ten years of rejection slips is nature's way of telling you to stop
writing.
-- R. Geis
Advertise here
advertisements
our advertisers
