H
Hi~~^^
I just ask about Modbus TCP Protocol. We're going little big project. Customer want to connect and receive data from 2500pcs device through MODBUS TCP Protocol without OPC server at the same time.
I afraid disconnect of MODBUS TCP.
Because of MODBUS TCP is Ethernet Protocol.
As I know it's different Ethernet TCP/IP Protocol.
Customer should receive data throgh MODBUS TCP in real time.
Server PC should receive within 200ms from 2500pcs device at the same time.
In general, data size of one device is about 100 bytes.
Please advice to us how to connect 2500pcs device through MODBUS TCP safely.
Thank you
Thank you
