What seems to be the problem if the 24VDC from the safety barrier drops down to 0VDC every time I connect my temp transmitter. Is there a short or open circuit in my loop? Is there any factor from this:
Wire Resistance disconnected from transmitter is approximately 2030 ohms. I should get open or maximum resistance from my multimeter right?
Resistance when transmitter is connected is approximately 2070 ohms.
