O
Hi.
I am looking for air flow meters that can measure l/s of air flowing through a utility tunnel. The meters will not be installed in any ducts - they will measure the flow through a cross section 3meter by 1.5 meters. Expected velocities in the tunnel are - minimum 0.3 meter/sec to a nominal of 0.8 meter per second.
Can anyone suggest a suitable air flow meter for this application?
Thanks you!
Thanks you!
