Dear Madam, Dear Sir,
I have a problem with the Modbus IO Server via Ethernet within Labview 2012 and with the powermeter of Janitza. I just can read out zero values from the powermeter although the right address has been confirmed by Janitza. I believe that the IO Server has a data conversion problem which leads to a data type overflow which results in a zero value which is logged and can be seen via the DSM tool.
Can anyone confirm this behaviour or do I have a Labview/Modbus IO server configuration problem?
Thank you in advance.
Josef
Josef
