Hi guys,
I am facing problem with Krone Summit8800 NG flow meter. The range for pressure transmitter is 200 psig (max.). But the line pressure is 202~205 psig. The feedback of transmitter to flow computer is OK i.e. it shows the exact value. But while print the data sheet (measurement of total volumetric flow, HHV, etc.) it pick a constant pressure 25.74 psi to calculate the total flow rate. Can Anyone please help me regarding the problem?
Secondly I want to know which dp is used for calculation the HIdp (high DP) or the Ldp (low DP) or the basic using HIdp & Ldp??
please reply.
Thanks in advance,
Rokan
please reply.
Thanks in advance,
Rokan
