T
I have an issue with a Type K thermocouple setup. I have about 10-15°C difference between what is read at the thermocouple and what I read at the compensation cable before it connects into the DCS card. It is old WX comp cable over a hot float glass line. The T/C reads 105°C but getting 120°C on DCS. Now I believe the cable is degrading and the insulation is failing as it is brittle in parts. the Thermocouple/comp cable junction is at a high temperature. also the dissimilar metals of the T/C and comp cable may be giving us problems?
I'm not an expert with this so any info would help.
