R
my qustion is, if i have a differential pressure transmitter installed on a tank, for convenience i need to shift the transmitter horizontally to a different location (i meant i am not shifting its point from the datum.), so i'm using a capillary. so does it make any effect on the reading? will the reading change if i use a capillary??
