What is the difference between Simple cycle gas turbines and combined cycle gas turbines?
Is a gas turbine combined with waste heat recovery boiler called combined cycle? Or, is only Gas Turbine combined with waste heat recovery and a steam turbine called a combined cycle? Is presence of steam turbine necessary for it to be called combined cycle?
And, what role does modulating IGV angle play in both simple cycle and combined cycle? I want to know more about exhaust temperature maximizing effect with IGV angle modulation...
